I noticed when trying to test a scene when you have override mtl enabled normal CPU and then switch to GPU mode, it won't render the override anymore instead just the regular materials. I looked at the manual to see if this function works or not, but found nothing. I also noticed while in the render settings, override mtl is no longer available. So is this function not available or am I doing something wrong?
Does "Override Mtl" not work in GPU Next?
Changing the Renderer to either CPU or GPU resets the settings to their defaults. This means that the 'Override mtl' option would be returned to its deactivated state.
The function is available in V-Ray NEXT GPU. You can find it in the V-Ray tab, under the Render settings rollout (see screenshot).
http://ftp.chaosgroup.com/support/3d...6_14-16-16.png
