Hello! =D
I got some new GPUs and decided to get back into Vray after some time using Corona. When
Vray GPU is generating some really strange airtfacts when I use a falloff map and a bump map. Here's a comparison so you can see what's going on (sorry for the contrast difference - didn't had the patience to convert all the color correction values)
As you can see, Corona has a way higher bump map and no surprises with the falloff map imdependly of camera distance. On the other hand, Vray GPU has a lower bump effect and the falloff goes crazy if zoom in.
Any idea of what's going on?
Thanks!
Thanks!
