Saving current render to history, corrupts/looses the effectsResult
  • Saving current render to history, corrupts/looses the effectsResult
    Hi guys
    Vray #("4.20.90", "29628", "21071ad8")
    While rendering with defaults for GPU and after the denoiser did at least 1 pass, saving the image to history while it's rendering corrupts/looses the effectsResult. This does not happen with CPU Advanced
    Kind Regards,
    Morne
    This seems to happen only when the denoising pass has not yet fully passed, which is normal.
      ok, but as mentioned, with progressive on cpu advanced, I still get the effectsresult, while with GPU progressive, I dont
      Would be nice to get what I see in the VFB at the time of saving
      Kind Regards,
      Morne
        For example, this was after 15 minutes, when the denoiser already made several passes, but I saved to history during render. When you reload the image via the history list and go the the effects result, it comes up with this corruption. If you keep reloading same image, or even any other image that was saved in same way, then the lines become worse and worse till eventually the VFB is almost completely white. You have to switch to any other render element, and back to the efects channel, to view the original corruption. Click image for larger version  Name:	corruption.JPG Views:	1 Size:	289.2 KB ID:	1052043
        I can click "update" in the denoiser element, to recover it (well not really recover, as it does a full new denoise)
        Again, this corruption DOES NOT occur when saving while rendering with progressive advanced CPU
        Kind Regards,
        Morne
          As a workaround, I'm now 1st cancelling the render, then updating the denoiser, then only saving to history
          Kind Regards,
          Morne
            Actually, I get the corruption even if I leave the render to finish on GPU. The saved history vrimg file's effectsResult is ALWAYS corrupt as above
            Kind Regards,
            Morne
              Can't seem to break to effectsResult channel in the described manner. Does this happen on a specific scene or on a specific workstation? If it is scene-specific, could you send the file to support@chaosgroup.com so we can take a look?
