Dark edge on geometry when using DOF
  • Dark edge on geometry when using DOF
    I was testing out the RTX GPU build on an animation. I found that when I enable DOF I get a dark edge on my geometry:
    http://jeffpatton.net/forum_posts/VR..._dark-edge.gif
    DOF on/off comparison:
    The scene is using a VRay Dome light with HDRI assigned to it FWIW.
    - Jeff Patton -
    Could you send the scene to support@chaosgroup.com so we can take a look? Mention your V-Ray, host platform, GPU driver and OS versions and your GPU model in the e-mail along with a link to this thread.
      Can do. Email submitted with info & file. Thanks.
      - Jeff Patton -
        Thanks for the provided files. It seems the issue is related to the render settings' depth of field (which affects Standard 3ds Max cameras and the perspective view) and V-Ray GPU. I've forwarded the information (Bug-tracker id: VGPU-4399) to our developers for investigation. As a workaround, use either a V-Ray camera or Max's physical camera.
          Thanks for looking into it. I'll change the camera over to the V-Ray camera.
          - Jeff Patton -
