Pixelated environment background
  • Pixelated environment background
    I shot a detailed panorama at 16000x8000 and try to use it as background image (JPG). But in GPU mode only I get a downscaled version shown, no matter what I set at the GPU textures settings (V-Ray for Rhino). In CPU mode anything looks like expected. I hope it's a bug only and the env image should be shown in full resolution. What do you think?
    -Micha
    Hello, Micha,
    Do you use a Dome Light to project the image, it is slotted in the Environment Background slot or applied it to a surface?
    Would you be able to share with support@chaosgroup.com a simplified scene set up as the one you've illustrated?
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      Your questions leads me in the right direction - I have overseen that light domes are using a texture size option. It was at default 512. At 16000 it works. What do you recommend, is it a problem to use this option at high counts?
        It should be fine.
