Matte for Refl/Refr not working
  • Matte for Refl/Refr not working
    Has this always been not working and so waiting to implement, or is it not an achievable thing?
    Could you elaborate a bit more on the issue you are having? Maybe post a screenshot/simple scene, so we can take a look?
      Sorry, I thought it was probably spotted before. Here is the result from the exact same setup.
        So I just noticed you replied to this thread https://forums.chaosgroup.com/forum/...-wrapper-alpha
        I'm therefore assuming this is the same basic non-implemented feature.
        Which is a shame
          Unsure if this is the same issue, best you send the scene to support@chaosgroup.com so we can take a look and make a conclusion. Mention your V-Ray, host platform, GPU model/s, graphics driver versions and a link to this thread in the e-mail.
            Actually yes I agree, it's different.
            I just simplified the scene to send and noticed that with it set NOT to be a matte material but with the alpha contribution of 1.0 there are no reflections even in the beauty, though bizarrely if you set the alpha to -1.0 then they appear.
            https://www.dropbox.com/s/4quxcast7ck20v4/test.max?dl=0
            Vray 3.1 4.30.01 2080ti rtx win 10 441.41 driver
              Thanks for the provided scene. I am unsure what end result you would wish to produce since we changed the focus of the issue. From what I understood, you would like to see both the reflections and shadows in the alpha channel via the matte plane when rendering on the GPU? Is that correct?
                Yes, just the same behaviour as what happens when using CPU only. Usage would be a product on a shiny black floor for example as in a recent post I commented on.
                I only discovered the GPU issue by replying with a process for doing this kind of shot.
                The GPU result is as in the scene and the images in this post - it's currently not possible to have the reflection appear in the matte at all.
                Apologies - I didn't intend to change the focus - it's just something extra weird that I happened to notice when sending the simple scene. It's surely not intended to work like that.
                Do you see what I mean in the general sense?
                I can provide more example images of what exactly is happening and the various settings used, if that helps, although that scene should exemplify it all.
                  I understand, however, currently, you cannot have both the reflections and the matte shadows in the alpha with V-Ray GPU (as you already concluded). Our developers are informed about the issue and it is on their to-do lists.
                    Cool...all I needed to know, thanks
                    Just typical I guess for me, in that I just got a major gfx upgrade only to find that a lot of the things I wanted to utilise don't currently work.
                    Luckily I got a new cpu too, so not all lost and hopefully gpu fixes upcoming at some point.
