Bug: I get issues when I have the vray denoiser set to generate render elements, and have the the frame buffer to write a EXR file and yet use Iterative rendering
  • Bug: I get issues when I have the vray denoiser set to generate render elements, and have the the frame buffer to write a EXR file and yet use Iterative rendering
    I get an error first, then a crash.
    http://www.jd3d.co.uk - Vray Mentor
    Hi JD3D_CGI
    Can you share the exact V-Ray/host platform versions used, together with information about the error message? Log/dump files and any screenshots showing this would be appreciated.
    Nikoleta Garkova | chaos.com
      I've sent this scene already and support only mentioned the physical materials- but they ignored the part about the denoiser causing crashes
      Literally, I have narrowed it down to the Vray denoiser causing a crash, whereas the nvidia one does not.
        Thank you for the scene file. We managed to reproduce the crash here. We will investigate your scene more and we will post an update.
        Martin Minev | chaos.com
