Upon drawing a new rendered region in the VFB while in IPR mode, I get the following: error: Unhandled exception occurred, will exit render loop
I have recently downloaded V-Ray 5 for Max 2021 and started testing GPU with a relatively simple scene. Materials are overriden with a VrayMtl on default settings. The log in the %temp% folder gives no clue of the error other than the error message above, repeated 10 times. Max continues to function but V-Ray is frozen and another renderer cannot be selected. A Max restart is required to enable V-Ray again. The scene was originally composed on different computer with FStorm; although, as far as I can see, all FStorm items are removed. In addition, two errors appear upon opening the file - an error regarding chamfers created with a newer "chamfer version" than the current, "version 410" vs "version 400"; and an error regarding a missing Floor Generator DLL, which was installed on the other computer but not this one. I'm including this info because it may be pertinent to the render error rather than V-Ray itself.
