I am experiencing issues with incorrect GPUs being used for rendering if I enable and use Distributed Rendering. Please see the screenshot below. You can clearly see that I've disabled the GTX 1080, yet it's being used. I tried rebooting my PC, but that didn't fix it. The opposite happens as well - I've enabled the GTX 1080 Ti, but it's not being used. The issue only goes away if I disable and don't use Distributed Rendering.
The incorrect GPUs are being used for rendering if I enable Distributed Rendering
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 5090 32GB + GPU Driver 572.83Tags: None
Hello,
I still have this issue. Any help, please?Aleksandar Mitov
96GB DDR5
Hi have you set up your devices according to this method - https://docs.chaos.com/display/VMAX/...DADevicesforDR
Thanks for the reply. I haven't set up anything, as far as I know. Here's what this looks like on my end. Do I need to make any changes? Do I also need to make any changes on any other computer that is used for DR rendering with the GPU engine?
Aleksandar Mitov
96GB DDR5
Got it. I checked all checkboxes, restarted Max and now Vray GPU uses all of the devices that I pick. Thanks! I am curious though, why is this additional step necessary? There's already a list in the render settings in 3ds Max to select the devices I want to be used for rendering. It doesn't make sense to me.Aleksandar Mitov
96GB DDR5
Thanks, Muhammed_Hamed !Aleksandar Mitov
96GB DDR5
