Hi There
Could you please look into this weird bug.
I use inherit visibility a lot during my assembly animations.
How ever I noticed that once I started using the GPU engine. some objects did not respect the gradual fade that others did. The problem objects only had visibility either full on, or full off.
The problem seems to be layered /multi materials. see image.
Could you please download the file, and see if the problem persists with your machines.
https://we.tl/t-tpTUcJmZ8C
Thank you.
Thank you.
