Maya 2022 | UVW Randomizer issue with displacement maps in V-Ray GPU mode
  • Maya 2022 | UVW Randomizer issue with displacement maps in V-Ray GPU mode
    Forgive me if this is a known limitation or bug. I am trying to use the UVW Randomizer with Stochastic Tiling in V-Ray GPU mode; however, the displacement results are not correct. All other maps work fine, and the displacement works as expected in CPU mode. I read some posts in regards to an issue with using the 2D Displacement type, however, I am using the Normal Displacement type. Thanks.
    V-Ray 5 for Maya, update 2
    (v5.20.00 from Nov 9 2021)
    Click image for larger version  Name:	GPU - UVW Randomizer.jpg Views:	0 Size:	769.2 KB ID:	1134373
    Above: Messed up displacement
    Click image for larger version  Name:	CPU - UVW Randomizer.jpg Views:	0 Size:	761.5 KB ID:	1134374
    Click image for larger version  Name:	GPU - No UVW Randomizer.jpg Views:	0 Size:	746.8 KB ID:	1134375
    Thanks for the report, this was fixed for CPU a while back. I will investigate the GPU behavior
    Any chance you can upload me this simple scene?
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Sure. I've stripped everything besides the plane and converted the displacement map to a jpg to lower the file size.
      Thanks for taking a look.
        Thank you!
        I will take a look and report back
        Best,
        Muhammed
        Muhammed Hamed
        chaos.com
          Thanks for the provided scene, Issue is logged to VMAYA-10967
          I will update the thread when this is solved
          Best,
          Muhammed
          Muhammed Hamed
          chaos.com
