Vray 5 GPU Update Version 2.1 - Shadow Catcher Issue
  • Vray 5 GPU Update Version 2.1 - Shadow Catcher Issue
    Does anyone have this issue where geometry touching the shadow catcher plane,
    seems like there is 1px wide empty space occurs when the image is denoised ?
    Im uploading the project file as well.
    I have tried using both methods i know of where i changed Alpha contribution from Vray object prop. & from creating a VrayMtlWrapper and overriding alpha cont. from there.
    Is it a bug or am i doing something wrong? Could someone help please ?
    Hi you are right there is something going on with the denoised image. I did a few tests and it seems the alpha channel is what gets broken.
    I tried to switch to custom denoiser and set it like this:
    It seems to resolve the issue with alpha channel:
    The image also looks normal:
    I will continue to investigate this and get back to you.
    Vladimir Krastev | chaos.com
      Hi it turned out that currently the VRayDenoiser disturbs the alpha shadow from a matte surface. The issue is logged under VMAYA-10897 for developer review.
