I have 4 specific colors that my client wants placed on a floor in a random pattern.
They will be 12inch x 12inch square tiles.
I tried generic material>tiles in the texture slot >with Multi-Sub plugged into the color tile texture slot.
Then applying to 1 flat surface (floor).
I can’t get it to work properly.
Will this method work?
I also made a series of 12”x12” surfaces, then applied the material to all of them. That works with CPU, CUDA/GPU doesn’t’ work.
Or is there another way?
Using Vray 5.106, Rhino 7.15, Cuda (CPU & GPU).
Thank you for your assistance,
Glenn
Glenn
