Vray clipper in Maya
  • Vray clipper in Maya
    Im having an issue when rendering the Vray clipper in maya using the GPU. When I have two object with two clippers, one clipper exclusively assigned to each object. See below.
ID:	1165299Click image for larger version
ID:	1165300​Is this a bug or am I doing something incorrectly. It seems I do not have this issue when I switch over to CPU.
    thanks!
    Hey chris_henderson
    Geometry clipping is not supported on GPU in the current builds, the implementation is WIP at the moment and nearly finished. We have been working on implemeting this for a while, It will be part of the next update
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Can you tell me when the next update will be?
        Hi Chris,
        I cannot say when the next update will be released publicly, if you are interested in testing the mesh clipper in Maya let me know.
        I will provide a test build
        Best,
        Muhammed
        Muhammed Hamed
        chaos.com
          He is not using geo to clip.
          The issue is the visible face you see in the render.
          https://linktr.ee/cg_oglu
          Ryzen 5950, Geforce 3060, 128GB ram
            Thanks oglu
            I got confused by the setup, my mistake
            The issues for the visible face is logged in our system under VGPU-1964
            I increased the priority on this issue and added to our development roadmap. It is a good idea to get this fixed with the new clipper updates
            I will update the post once this is fixed
            Best,
            Muhammed
            Muhammed Hamed
            chaos.com
