Vray Material editor issue
  • Vray Material editor issue
    I cannot for the life of me figure out the issue in the attached image. Im not getting a proper viewport representation of the material. I have checked the assigned renderer and its all vray. I have switched it etc. Any help?
    It seems your "Native 3ds max material swatches" option (Render Setup > Settings > Global Switches) is active. Try turning it off and updating the shader.
      Unfortunately its turned off .. I turned it on then back off and same thing. No change.
        That's odd. Because what's shown in the screencap is the 3ds max native swatches. Does it happen on a fresh scene? For starters, you can try a reinstall or a reset to the 3ds Max defaults.
          Very weird! Ill have to give fresh 3ds max install a try.
            I meant a fresh V-Ray install. Try that first.
              I actually did that before I posted this. I upgraded to the latest vray version and nothing changed.
                I see. Try resetting 3ds Max to its defaults as well.
                  I tried resetting the user preferences of 3ds max and nothing changed it.. I may have to try reinstalling 3ds max.
                    So i have updated 3ds max and still hit with the same issues. In this machine, I have 8 rtx a6000's and an AMD EPYC 7543
                      Do you have any unusual Environment Variables set, which may relate to the issue?
