I have an exterior scene where the curb comes out blurry with "on-deman mip-mapped" texture mode. Every other object in the scene seems to render perfectly fine and sharp except for the curb. If I use "full-size" or "compressed" texture mode, this doesn't happen. Is this a bug or some sort of misconfiguration of my material or scene? Please check the screenshots below. This is a crop from a 4400 x 2750 px image.
A specific object comes out blurry with "on-demand mip-mapped" texture mode
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 3090 24GB + GPU Driver 566.14Tags: None
Hm. I have a feeling this is happening because the curb is an individual object stretched a big distance along the scene, which possibly causes GPU to use mipmapping on it. Could you simplify the scene and attach (or send) it?
Sure, see attached.Aleksandar Mitov
96GB DDR5
Thanks for the provided scene. I managed to debug it and found out there's a problem when using VRayTriplanar projected textures and On-demand mipmapping. There are visible artifacts with lower size Triplanar values and blurriness with higher values. I've logged the issue (internal bug-tracker id: VGPU-6156) for developer investigation. For now, you could either render with Full-size textures or use another method of projecting the textures and stick to mipmapping.
- Likes 1
Thanks! I'll use full-size textures, I think they fit fine in VRAM for this scene.Aleksandar Mitov
96GB DDR5
