A specific object comes out blurry with "on-demand mip-mapped" texture mode
  • A specific object comes out blurry with "on-demand mip-mapped" texture mode
    I have an exterior scene where the curb comes out blurry with "on-deman mip-mapped" texture mode. Every other object in the scene seems to render perfectly fine and sharp except for the curb. If I use "full-size" or "compressed" texture mode, this doesn't happen. Is this a bug or some sort of misconfiguration of my material or scene? Please check the screenshots below. This is a crop from a 4400 x 2750 px image.
    Click image for larger version  Name:	gpu_texture_mode_on-deman_mip-mapped.jpg Views:	0 Size:	295.1 KB ID:	1180186 Click image for larger version  Name:	gpu_texture_mode_full-size.jpg Views:	0 Size:	295.3 KB ID:	1180187
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    3ds Max 2023.2.2 + Vray 7
    AMD Ryzen 9 9950X 16-core
    64GB DDR5
    GeForce RTX 3090 24GB + GPU Driver 565.90
    Hm. I have a feeling this is happening because the curb is an individual object stretched a big distance along the scene, which possibly causes GPU to use mipmapping on it. Could you simplify the scene and attach (or send) it?
      Sure, see attached.
      Aleksandar Mitov
      64GB DDR5
        Thanks for the provided scene. I managed to debug it and found out there's a problem when using VRayTriplanar projected textures and On-demand mipmapping. There are visible artifacts with lower size Triplanar values and blurriness with higher values. I've logged the issue (internal bug-tracker id: VGPU-6156) for developer investigation. For now, you could either render with Full-size textures or use another method of projecting the textures and stick to mipmapping.
          Thanks! I'll use full-size textures, I think they fit fine in VRAM for this scene.
          Aleksandar Mitov
          64GB DDR5
