VRayLightMtl's "emit light on back side" feature not working
  • VRayLightMtl's "emit light on back side" feature not working
    Hi. The "emit light on back side" feature of VRayLightMtl doesn't work in V-Ray 6 Update 1.2. I tested both RTX and CUDA. The help docs say it should be supported. Is this a bug or are the help docs wrong? I've plugged the VRayLightMtl into a Double Sided material as a workaround.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Hello,
    "Emit light on back side" indeed is not supported with GPU yet, we have it logged for improvement (internal tracking number:VGPU-718 ).Thank you for the report and apologies for the inconvenience! We will check the doc pages and bring them up-to-date in that regard.
    Best Regards
    Maria Keskinova
    V-Ray for 3ds Max QA Specialist
    Chaos
      Thanks for clarifying, Maria.
      Aleksandar Mitov
      96GB DDR5
        Hi Vray team,
        Is this still unsupported on GPU? It really seems like an elementary feature for those of us who can't afford to render on a CPU need to use.
        Thanks,
          Hey, trainofthought. You should be able to work around this problem by putting the VrayLightMtl into the "Front material" slot of a Vray2sidedMtl and setting the Translucency color to black. Then apply this 2sided material to the object. I think this is how I made it work with GPU when I found this problem.
          Aleksandar Mitov
          96GB DDR5
            Thanks Alex, I will try this!
