Forest Pack scatters grass in a drastically different way with compared to CPU
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 5090 32GB + GPU Driver 572.83Tags: None
If the map you're using is procedural then that would cause this, as GPU does procedurals differently.
If that's the case then this solution may fix it https://forums.chaos.com/forum/v-ray...p-inconsistent
The map is a texture in JPG format loaded through VrayBitmap. Sorry, I forgot to mention this.Aleksandar Mitov
96GB DDR5
OT-that grass looks really great...is it a standard FP preset or something you worked up. Even the patchy one looks pretty nice (at least for patchy grass). I've always been a little disappointed with the standard preset "lawns" looking too regular and unrealistic - wondering if I should revisit them.www.dpict3d.com - "That's a very nice rendering, Dave. I think you've improved a great deal." - HAL9000... At least I have one fan.
Hi, dlparisi . The grass is an asset I bought from 3dsky and modified the diffuse textures a bit. The unevenness comes from the stripes texture used in the scale slot of the 2 Forest Pack objects.Aleksandar Mitov
96GB DDR5
