V-Ray GPU not working at all.
  • #16
    Hi guys,
    I want to share my issue regardind to this topic. Today I had the same problem, all of a sudden the VRay GPU render stopped working after a 3dsmax crash.. I thought maybe some chaos server file was still loaded into memory and was giving this glitch...
    But then I thought looking into the Log file.. and for my surprise the last error was:
    Code:
    [2024/May/26|17:23:36] warning: Could not use any of the selected (1) hosts for distributed rendering!
    [2024/May/26|17:23:36] error: Local machine is not used for distributed rendering and no servers can join!
    [2024/May/26|17:23:36] Max ray intensity is enabled: rendered result may have incorrect brightness.
    [2024/May/26|17:23:36] [VRayRTMax::Render()] Cancelled before render​
    And I was using just my RTX4090.. never touched the Distributed Rendering ON option!!!! So maybe a bug, maybe a hidden shortcut I might be pressed and it just turned it on... I wanted to share this so the devs could say if there is such chance for this option be enable by accident..
    So other than that, it was just turn this option OFF, and the GPU render get back working again.. Yet using the latest Studio Driver v.555.85, and not the recommended version stated at the https://www.chaos.com/vray-gpu​ page
    My best,
    Rodrigo Sotero
    • #17
      Hi Rodrigo!
      Did you use the Vantage Live-link?
      It is usually the reason DR could be turned on
      On another note, we will be updating the GPU drivers soon. We are testing this now
      Best,
      Muhammed
      Muhammed Hamed
      V-Ray GPU product specialist
      chaos.com
      • #18
        Hi Muhammed! Thanks for your reply.
        Yes, I was using Vantage most of the time, but since my shaders was using both VRayDirt and Curvature, and unfortunatelly Vantage still won`t render both of it, I had switched to Vray GPU.
        So now I know that thats the culprit of turning DR on, thanks for the valuable information!
        Do you have an idea of when we will have Dirt and Curvature being rendered with Vantage?
        My best,
        Rodrigo Sotero
        • #19
          About Dirt and Curvature, they are on the roadmap for Chaos Vantage, they will be implemented at some point(not this year), although Dirt will probably affect interactive performance considerably
          Best,
          Muhamed
          Muhammed Hamed
          chaos.com
          • #20
            Great, having curvature would already do the trick for some things.. Since we now have displacement, I`ve been using Vantage more. ^_^
            Let me ask you about SSS, I see that FastSSS2 is there at the docs, but I still can not make SSS work with Vantage... is there any trick on how to render SSS with Vantage?
            Thanks​
            • #21
              Hi rodrigo_sotero
              SSS is still not implemented in Vantage, and we haven't decided on which SSS model to support in Vantage yet. It is on our roadmap to do, higher priority than V-Ray Dirt and Curvature
              Best,
              Muhammed
              Muhammed Hamed
              chaos.com
              • #22
                Thanks for your reply, @Muhammed_Hamed​ . Those are really some special and important features to exist in Vantage, would improve a lot the final results of our projects.
                I'll be waiting for it
                My best regards,
                Rodrigo Sotero
                • #23
                  Thank you for the feedback as always rodrigo_sotero
                  I talked to the Vantage product manager about your requests and added your vote to the corresponding tickets in our system
                  Best,
                  Muhammed
                  Muhammed Hamed
                  chaos.com
