3x quadro a4000 gpu memory errors
  • 3x quadro a4000 gpu memory errors
    As i mentioned in headline , i am getting all sorts of memory issues on vray gpu , scene running fine with cpu mode, scene was build up in gpu , having 4.1 gb. its quite big regarding geometry and textures . i tried to optimalize it using small res textures but didnt help at all . Is there anything wrong with my card setup , because those cards running very well with fstorm and redshift , but vray somehow cant work well, 3ds max + vray
    Hope you can help me. best regards
    M
    Hi, thanks for posting. Please try the V-Ray Benchmark tool as a first step. If it works then your setup is fine and there is something in the scene or you are running out of memory. Try to monitor your GPU parameters during rendering with a dedicated hardware monitoring tool.
    If you are not running out of video memory and everything looks ok then we could turn our attention to your scene. But please complete these initial tests, share the results and we will continue with the scene later.
    Vladimir Krastev | chaos.com
      Click image for larger version  Name:	Screenshot 2023-11-16 133004.png Views:	0 Size:	278.7 KB ID:	1195208I tested vray benchmark ,
        Hi, since the VRay Benchmark Tool seems to run with no issues then the next steps are:
        1. you are running out of memory on your production scene (for instance a mistake in the displacement settings could easily eat all your memory in a seemingly "small" scene)
        2. there is an issue with your scene that is not that obvious or there is a bug that manifests only if specific conditions are met and you got "lucky" with your scene and hit the bug
        Please monitor your hardware during rendering and if you have enough memory but still get errors, send us your scene here or through the support contact form for review.
          Sure , here it is , please help me to find out what is going on
          Thank you ,, Best regards
          https://tritondigital.wetransfer.com...ource=sendgrid
            Hi, thanks for the scene.
            Could you follow this important step and share the results:
            You can use this tool or any other dedicated GPU hardware monitoring tool to check if you have enough memory.
              Hello,
              Thank you for the scene!
              I'm looking into this now on a machine with a similar multi-GPU setup
              Best,
              Muhammed
              Muhammed Hamed
              V-Ray GPU product specialist
              chaos.com
                Thank you , hope you will find out what is going on. Best regards
                  We caught the issue and there is a fix in in our internal builds for some time. Sorry I didn't update the thread as fast
                  These type of errors will be easier to tackle with all new builds
                  Best,
                  Muhammed
                  Muhammed Hamed
                  chaos.com
