Antialiasing Issue for progressive vs bucket
  • Antialiasing Issue for progressive vs bucket
    on GPU RTX
    when I compare progressive vs bucket renders it is visible that the edges are not correct for the progressive method, and it is more visible when I render selected objects and try to compose the render over and existing image, this was happening for years on different workstations and I finally decided to ask
    please advice.
    Hey Wessam,
    Progressive is the recommended way to use V-Ray GPU, on a simple scene I cannot reproduce the antialising issue you mentioned
    Do you have a screenshot or scene? we need to reproduce this on our end
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      I wonder if the OP is referring to the rough edges often seen (esp with progressive) on renders with Render Mask set. ??
        yes, exactly
          Not sure if there is a way to avoid. I usually don't use progressive. In fact, I hardly use progressive for anything.
          It does put a warning in the log (with some interesting spelling):
          Code:
           Warning : Render subsets and progressive sampling lead to artefacts along object edges.
            You can make a matte in post (from a previous render's alpha perhaps) and expand the matte to render more than you need, then shrink and feather it when you composite. That is what I have done when I needed to render individual objects. But normally we just end up re-rendering the entire frame.
              Code:
              Did you mean in the spelling of 'artefacts' ?
              That's totally fine, as it's just the UK version.
              It's the 'lead' that is incorrect, as it should be 'leads'.
              Just saying
                Chiefly British I did not recognize that was one of the British Flavours.
                Given the subject is plural I would say “lead” is correct, rather than “leads.”
                EDIT: But I suppose the meaning implies, "Render subsets with progressive sampling leads to artefacts along object edges," which would indeed be singular, and make "leads" correct, as well as be more clear.
                EDIT REDUX: What the heck am I talking about? “Subsets” is still plural either way. So “lead” it is. Carry on.
                  Thanks, though that’s a work around bur still not perfect, specially with high resolution renders and super picky clients
                    Originally posted by Muhammed_Hamed View Post
                    Hey Wessam,
                    Best,
                    Muhammed
                    Thanks, tbh it’s amazing how it is in the log like the previous post, and you guys are not able to reproduce. The issue been there for years, I want to help you with the investigation but I am on a tight deadline currently.
                      I thought that 'render subsets' was the parameter/option label, so singular, but apparently not.
                      Given the statement implies that the two things, used together, produce artefacts, then leads is still correct I think, instictively (I'll check with my tame linguist later), but a simple
                      solution would be to use 'will lead to' or a variation thereof
                      I do love a bit of pedantry in the morning
                      Sorry OP...didn't mean to hijack
                        @Muhammed_Hamed
                        please check the screenshots attached,
                        Again the issue is worst when making a masked render, (like render selected)
Name:	render issue.jpg
