Render error
  • Render error
    Getting this error in the log:
    Error : Failed to build Embree tree for dynamic mesh: [EmbreeStaticMeshTree::build] 1: Committing (join) scene failed!
    Any ideas what this means?
    Thanks
    You are most likely running out of memory. Check if the issue occurs if you render lower resolution/ lower texture size/ lower displacement edge length/ etc. while monitoring your VRAM usage.
      Have plenty of mem available so I don't think that is the culprit.
        In that case, send the scene so we can troubleshoot.
          Sure thing, sent
            Thanks. Just so you know, I'm troubleshooting it. There seems to be some kind of a memory leak. Will post again with more info.
              Is this the only error you're getting? My previous post refered to something else. Otherwise, I found the culprit of the embree error message - its one of the objects named "3dSolid". Its a large plane, located below the chairs in the backroom (viewed from camera LobbyV1). Posting a screencap of its location in the Scene Explorer. Try deleting it and see if that makes the error dissappear. I am unsure of its reason, however, I'll log the scene for investigation.
                Wow, thanks!
                These are objects imported from Rhino, should have known....
