Stopping a render
  • Stopping a render
    There needs to be a workaround for stopping a GPU render. I can't wait 15 minutes every time I hit stop/cancel. How is killing MAX and launching it again the way people are doing it? I literally forget why I even canceled the render in the first place because it takes so long. If you didn't save before you hit render and have to cancel, you lose work. There has to be a solution.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    We have a fix in internal builds, usually it happens with exterior scenes and many instances.
    If there is a chance to share a sample scene to test the fix, it will be very helpful. This change could be ported to stable, I will check with the devs
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      I timed it on a stopwatch this morning - 14 minutes and 32 seconds! I will wrap this up and send it over as soon as I can.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Is there a fix for the nightlies? I am uploading the files now and will share them when they are done uploading. I can't function when I have to wait 15 minutes every time I stop a render.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Best,
          Muhammed
          https://drive.google.com/drive/folde...usp=drive_link
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Please let me know when you have downloaded so I can delete it.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Thanks a lot!
              I received your files and I'm testing your scene now, I will follow up shortly
              Best,
              Muhammed
              Muhammed Hamed
              chaos.com
                I tested your scene with the fix, it works nicely! stopping the render takes less than 10 seconds
                The increased system memory usage is about the render elements you have in the scene, you have a lot of render elements. We will investigate and see what is causing issues
                For the time being, use the CUDA engine and try to use the least amount of render elements in your scene. The scene is workable in IPR with the current stable build
                One more tip, for interactive rendering swap GI to BF. It works much better on GPU. See my post on using interactive rendering here
                I added your scene to our tests, it is very helpful. Thanks again!
                Best,
                Muhammed
                Muhammed Hamed
                chaos.com
                  I have spent a few hours testing your scene with our fix, it seems that the rendering performance is a lot better as well in the new build, not just time to first pixel or start/stop rendering. Would you be interested in trying this build on you machine?
                  If you have any similar exterior scenes with forest pack instances that are slow to first pixel, it will help our team to test/debug
                  Thanks!
                  Best,
                  Muhammed
                  Muhammed Hamed
                  chaos.com
                    Thanks!
                    Best,
                    Muhammed
                    Yes, please! I just ordered a second 4090, so I am invested in GPU now
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Congratulations on the new GPU
                      which version of 3Ds Max are you using?
                      I will send you an Email with a build
                      Best,
                      Muhammed
                      Muhammed Hamed
                      chaos.com
                        I amusing MAX 2024, but MAX 2025 as soon as Railclone and Forest Pack gets their updates out.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Built sent over Email
                          Best,
                          Muhammed
                          Muhammed Hamed
                          chaos.com
                            Received and installed. I'll test this week. Thank you!
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                              There is another improvement to your scene, about time to first pixel. It is now 88.92 seconds compared to 130 seconds in stable builds, and less than 10 seconds to stop interactive rendering
                              This scene is very helpful to us, we are looking into other improvements to make it render faster
                              I should have a new build ready soon, if you have time to experiment
                              Best,
                              Muhammed
                              Muhammed Hamed
                              chaos.com
