Resources
  • Resources
    Is it safe to say my scene is too large for my available VRAM? Why does GPU render use so much memory (regular RAM)? When I render with the CPU it only uses 1/4 of my memory.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    I'm able to reproduce this on my side, with the scene you sent me
    This is not expected to happen, this seems to be about your setup with Forest Pack
    We will investigate and get back to you
    On another note, the warning in the log is about running out of GPU memory, it affects rendering performance considerably
    I have some tips in this thread regarding optimizations
    in short, if you swap engine to CUDA and use Use System Memory for Textures option this warning will disappear
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Update, deleting render Elements seems to fix the system memory issues with this scene, it uses around 50 GB. Slightly more than the standard V-Ray renderer. we are still investigating
      Best,
      Muhammed
      Muhammed Hamed
      chaos.com
        Okay, thank you! I didn't think about checking that.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          It is probably PSD Manager masking out all of my layers. Other than that, I don't have too many elements, at least nothing that seems too many.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
