Using VFB in Composite mode makes my image darker
  • Using VFB in Composite mode makes my image darker
    I've got a very simple setup in the VFB where I use "Composite" to layer just 2 render elements - RGB color and VrayDenoiser. Both using "Normal" blending mode. When I render an image from scratch (all render channels cleared with "Clear image", the rendered image is substantially darker than it should be. If I turn on and off any of the Composite layers, the exposure becomes correct again. This happens with the CPU engine as well, if I remember correctly. Am I doing something wrong?
    Attached below is a video I recorded that hopefully demonstrates this clearly.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Don't add the denoiser to the composite, only RGB.
    Yavor Rubenov
    V-Ray for 3ds Max developer
      what if you wanted to just denoise certain areas, using a mask?
      e: info@adriandenne.com
      w: www.adriandenne.com
        You can add masks to the denoiser layer.
        Yavor Rubenov
          That was it! Thanks!
          Aleksandar Mitov
          96GB DDR5
