Not releasing memory in RTX mode
  • #16
    Muhammed_Hamed I just tried the new studio driver that was released today and there is an improvement but it's not solved. The test scene I send you earlier now slows down around frame 40 instead of frame 10. So it definitely leaks less..
    • #17
      I have the same issue (see this thread for more details: https://forums.chaos.com/forum/v-ray...ssive-sampling).
      64GB apparently is not enough to render a simple scene a few times in a row (without 3ds max restart). How can I fix this issue please?
      • #18
        lars_snelders Muhammed_Hamed
        Confirming studio driver 572.16 appears to be working correctly (with stills, I don't make animations). Releasing Vram shortly after rendering and I use the "system memory for texture" option. That seems to be using less as well, or not stacking/leaking like 566.14 did.
        Based on same file for both drivers, 572.16 was installed then system restart. Significantly less Vram usage and holding right after render completed.
        Vray 6.20.06, Rhino 8.15
        Ryzen 9 7900x, 64GB, RTX-4070TI OC,
        Glenn
        • #19
          Hi Lars,
          We have been investigating this last week, I will message you with a conclusion soon
          Best,
          Muhammed
          Muhammed Hamed
          V-Ray GPU product specialist
          chaos.com
          • #20
            Glenn
            Thanks for confirming!
            I'm glad it works now, we are checking other scenes that were problematic on our side
            Best,
            Muhammed
            Muhammed Hamed
            chaos.com
            • #21
              Did you try with the new d river 572.16 ?
              Muhammed Hamed
              chaos.com
              • #22
                Not yet, how will that help? Have you tested it internally?
                • #23
                  Yes, it seems to be related to the driver issues
                  Best,
                  Muhammed
                  Muhammed Hamed
                  chaos.com
                  • #24
                    Did it resolve RAM issues in your internal tests? Sorry, updating drivers in our case is a hassle so want to double check it fixes the problem
                    • #25
                      Understood, I will message you shortly
                      Best,
                      Muhammed
                      Muhammed Hamed
                      chaos.com
                      • #26
                        Your sequence renders fine with maximum memory usage of 16 GB, we have been able to render the whole sequence on a Quardro 6000
                        We will try with some Geforce cards today
                        This might be related to Geforce cards, I hope we could reproduce on our end
                        Best,
                        Muhammed
                        Muhammed Hamed
                        chaos.com
                        • #27
                          Hey lars_snelders
                          On 2x 3090s we were able to render the full animation sequence without memory leaks. It seems the new driver fully solves this issue
                          Could you please try again on your machine, reinstall the driver 572, check clean install option, restart the machine then render
                          If you are still having issues we will try on 4090s on our side, then we will remote into your machine to take a look at your setup
                          Best,
                          Muhammed
                          Muhammed Hamed
                          chaos.com
                          • #28
                            Thanks for the update Muhammed_Hamed thats indeed looking good. I’m out of the office for a couple of days but will try to render the scene again next week and report back.
                            • #29
                              Hi Muhammed_Hamed, confirming I was able to render the test scene without slowdown this time around! The first test with the new driver I didn't restart my machine, maybe that was the problem..
                              Thanks!
                              • #30
                                I'm glad to hear it works fine on your end!
                                For driver install, it works best to check clean install optoin on the installation dialogue then restart the machine. Then adjusting the Nvidia control panel settings
                                Best,
                                Muhammed
                                Muhammed Hamed
                                chaos.com
