I must be doing the same thing wrong.
Active shade pops up and says "V-Ray RT DEMO 320x240 max resolution for demo"
no vray.exe in task manager.
I have render res set at 320x240, and I made the perspective window really small. I just can't get it to do anything.
vrlservice.exe is running, but that's it.
this is in max2010 in WinXPx64
Black window
Also, in the Task Manager, do you see a process called "vray.exe" running?
Leave a comment:
Running on MAX 9 64bit - i got past the viewport size so i can see the messages and that it sends the scene out to the local render server
but... it stop at "Waiting for image data..." and remains black (i only have 1 teapot in the scene)
Leave a comment:
Nothing changes when I reduce the size of both the viewport and popout active shade. You mentioned set rt resolution, where is this located? The only thing printed in the window is "V-Ray RT Demo 32x 240 max resolution for demo".
Five minutes later: Seems to work now. Had to popout activeshade window for it to reset/fix. Thanks for the helpLast edited by etown; 01-06-2009, 09:14 AM.
Leave a comment:
Originally posted by suurland View Postmake the window smaller then 320x240
/Thomas
Leave a comment:
Originally posted by etown View PostCan't seem to get anything besides a black window with no errors (with the demo). Running max 2010. I tried to launch the vray RT server and that has no errors either. Am I missing something?
Leave a comment:
Black window
ThanksTags: None
Leave a comment:
