I notice quite a big difference in brightness between the RT window and the vray rendering.
I set all gamma stuff to 1.0, don't use the srgb button etc for this tests. So there are no gamma curves of any kind applied to the frame buffers or color mapping.
The scene is simply some teapots on a plane.
I noticed the problem first when rendering with a domelight, the difference in lighting is huge! With a plane light it is more subtle but still big enough to be annoying.
When rendering an image lit only by skylight and all direct lights turned off, the RT and normal render look exactly the same in terms of brightness.
Any ideas?
Wouter
Any ideas?
Wouter
