Realflow meshes won't update when frame changes
  • Realflow meshes won't update when frame changes
    I assume this has more to do with the Realflow plugin than it does with V-Ray RT, but some callback somewhere is not telling V-Ray RT that the Realflow mesh has changed once the frame changes, so it uses the same mesh the whole time. Any ideas?
    -Steve
    Stephen Hallquist
    Rayden, Inc.
    www.rayden.tv
    Does it update in the viewport? V-Ray RT uses the object validity interval to figure out if it needs to be updated or not. If the RealFlow mesh does not return this information correctly, then V-Ray RT has no way of knowing it.
      Yes it does update in the viewport.
      Stephen Hallquist
      Rayden, Inc.
      www.rayden.tv
        If I change a parameter in the RFMeshLoader plugin object it forces an update, dunno if that helps. :/
        Stephen Hallquist
        Rayden, Inc.
        www.rayden.tv
          If you select the realflow mesh, open a maxscript listener and type
          Code:
          vrscene_nodeMeshValidity $ currentTime
          what do you get?
            ....but I have to actually manually update a parameter, trying to key a parameter doesn't cause an update even though a value is changing.
            Stephen Hallquist
            Rayden, Inc.
            www.rayden.tv
              It returns:
              (interval 41f 41f)
              at frame 41, and it works at every frame, returning interval fr# fr#.
              Stephen Hallquist
              Rayden, Inc.
              www.rayden.tv
                Hm ok. Does the ActiveShade window refresh at all (i.e. re-start the rendering)? If yes, you can try turning on the paricles check-box in the RT settings and see if it helps.
                  It looks like if I put a relax modifier on top of the RF plugin and set it to 0 it does work. The active shade window does update, and in the viewport I see the mesh has changed, VrayRT doesn't see it though. How do I check the Particle systems check box if it's greyed out?
                  Thanks Vlado,
                  -Steve
                  Stephen Hallquist
                  Rayden, Inc.
                  www.rayden.tv
                    OK figured out the particle systems check box, still doesn't update the mesh properly even though it does update the active shade. Looks like I will use the modifier solution for now....
                    Stephen Hallquist
                    Rayden, Inc.
                    www.rayden.tv
                      You need to close the ActiveShade window, then you can change it - it is not possible to toggle it while the ActiveShade is running.
                        Just FYI to others having this problem, adding the modifier doesn't always work: some frames the mesh goes completely bonkers and it still likes to not update for a few frames. :/
                        Stephen Hallquist
                        Rayden, Inc.
                        www.rayden.tv
                          Hey Vlado,
                          Any more thoughts on this? It would be very sweet to be able to kick out fluid previews with VrayRT.
                          Thanks,
                          Stephen Hallquist
                          Rayden, Inc.
                          www.rayden.tv
                            Nope, I'm afraid I'm out of ideas. I have to reproduce this here to see what's going on - any help in this direction is welcome
                              What kind of help you need ? I can send you simple simulation. Plugins for 3dsmax itself are free...
                              CG Artist
