3dvision
  • 3dvision
    hi
    i just got 2 new 3d led monitors and the nvidia 3d Vision glasses and wanted to test it with vrayRT , but he tells me that my display config doesn`t support 3dvison
    benq monitor: http://www.alternate.de/html/product...onitore&l2=LED
    3dvision: http://www.alternate.de/html/solrSea...productDetails
    grafikcard: 2* evga gtx470
    http://www.alternate.de/html/product...l3=GeForce+GTX
    tyan non sli mainboard with 2 xeons 16gb ram
    the last drivers nvidia added support for this monitor, and everything is working fine
    VrayRT1.5 &vray2 testet and same issue
    is there any trick to get it moooooooore 3d ?
    yours
    thorsten
    Does the nVidia 3D vision test program work fine? Did you enable stereo 3D in the nVidia control panel?
      yes, testet a lot of 3d demos /games and http://www.maxunderground.com/archiv...ic_viewer.html is also working
      yours
      Thorsten
        -update-
        just updated nvidia driver to version 260.99(8.17.12.6099) but still no changes
        all things are working with 3dvision , but vrayRT not ..
        seams to be a bug
        yours
        thorsten
          I am in the same situation - got 3D vision glasses and a BenQ XL2410T monitor.. Stereo is working fine in games and in the Nvidia stereo test - but unfortunately not in Vray 2.0 RT
          I'm running 260.99 drivers on a GTX 480
            Ok, trying it here now...
              Hello,
              VRayRT does not support NVidia 3d Vision. It does support OpenGL stereo mode but you'll need suitable graphics card - e.g. most Quadro cards: http://www.nvidia.com/object/quadro_...echnology.html
              V-Ray for 3ds Max developer
                are there any future plans to support it ?
                would be a "nice to have"
                yours
                Thorsten
                  We tried, but we could not make it work (it was *very* unstable and interfered with the 3ds Max viewport system).
                    So, if I understand it correctly - this requires a Quadro card and 3D vision glasses with a special cable that connects directly to the GPU?
                    Here's a bit of info from Nvidia's site that might be useful if you happen to be based in Europe or Asia:
                    3D Vision glasses kits sold in Europe and Asia do not currently contain this cable. For Europe, an upgrade kit from PNY is available (P/N: QSP-3DV-KIT)
                      The OpenGL stereo mode will work with Quadro + Nvidia USB IR emitter too. The special cable that connects to the graphics card is not a strict requirement.
                      The USB IR emitter may lead to flickering at certain circumstances:
                      http://3dvision-blog.com/tag/nvidia-ir-emitter/
                        Okay - thanks for pointing that out..
