Hi ,
just bought the new 680 GTX Card (Gainward) and i was looking forward to see how fast this card is compared to a Quadro 4000.
So i started a scene as GPU-Render and it starts correctly but after a few seconds/Minutes the card drop out and screen will turn black, pc speaker makes alarm sounds, BSOD. This is not really what i expected
The 680 Card has two electricity Pins (8-Pin and 6-Pin). My HP Z800 only has to 6-Pin Plugs available. So i used a connector to plug two regular drive power Plugs into one new 6 Plug. And then a connector to take this 6-Plug and the one from the power supply into the 8-Pin from the GTX Card. The other 6-Pin from power supply is the mounted in the 6-Pin form the GTX Card. Anyone can follow?!
I don`t think it`s a power issue, but maybe i`m wrong?!
I`m also using the latest driver right now which is the 301.24 for the 680.
There is also a newer one (301.33) for the 690. Would it make sense to test this driver?
Anyone else having problems with their 680 Card. Anyone any tips what is faulty here?
Grüße
Oli Kentner
Grüße
Oli Kentner
