something wrong with active shade view compared to render output size
  • something wrong with active shade view compared to render output size
    Here are differences:
    I have no idea why object is positioned in frame differently on RT and on normal render.
    Luke Szeflinski
    :: www.lukx.com cgi
    Very strange, it totally doesn't match viewport:
    Luke Szeflinski
    :: www.lukx.com cgi
      The ActiveShade renderer and the production renderer have different output resolution settings (when you switch them, you'll notice that the Common tab of the render settings changes); make sure they match.
        also, you may have to stretch the active shade window's edges to see the whole image. It doesnt auto resize like the VFB when you change res
        Kind Regards,
        Morne
          I have been experiencing this as well and I have checked all output resolution settings. Happens in RT for both production and active shade but not for every scene.
            Example here where the bottom is cropped off on the final render. Un-ticking get resolution from Max in the V-Ray Frame Buffer and entering the same resolution also makes no difference.
ID:	847689Click image for larger version
ID:	847690Click image for larger version
              Can you post the scene file here?
              I made few tests and everything works as expected.
              Tashko Zashev | chaos.com
                I will sort out a scene and upload it shortly. I did some further investigation and it appears to only happen when using a camera. Tried both 3ds Max camera and V-Ray camera however in perspective it is fine.
                I have had it in the past when setting up slightly obscure camera angles and lens settings. If you go from out of the camera view and back into it again the view slightly shifts. It appears to lose its original position. I put this down to a 3ds Max issue as it happens in the viewport using any camera type and creating a completely new camera seems to fix it. Maybe this is linked some how? V-Ray RT not being able to render obscure views, however normal renderer is fine?
                  Hm, now i see that you are using Max 2012 and will check again, but it will be very helpful if i can test your scene as well.
                  I'm not sure if i understand this correctly, but V-Rat RT will update every change that is made for the camera lens parameters.
                    Apologies for not getting back sooner, but here is a Max file showing that the rendered result in RT is different to standard. The image size is the same yet in RT it appears to be zoomed in? By obscure views, I mean that sometimes this happens with cameras after they have been adjusted too much via the FOV/zoom controls etc. However if you create a new camera in the scene everything is fine.
                    Rendered View 001.zip
                      Thank you for sharing the file.
                      I'm reproducing the same issue with your scene here as well, probably there is a bug in this release (2.40.03). In build V-Ray 2.40.04 (available for download since a few days) some improvements are made for the RT engine and in my tests it produces the same render result as in the production one.
                      Would it be possible to update and test with?
                        Sure I will test the new update and report back.
                          Tested in build V-Ray 2.40.04 and it works fine, Thank you for your help.
