V-Ray RT Preview Animation Not works.
    To add the frame numbers, on the command line add explicitly the frame range, like -frames=1-100 (ideally we should write that into the .vrscene file though, I'll make a note about it).
    I'm not sure why the animation preview is not working - perhaps it would be good for one of the support guys to do a remote session with you to see what's going on.
      My problem was an nvidia driver problem. I was change my gtx 680 to my new K4200, change the nvidia driver and works fine. I don't know if the drivers has de problem, but now works fine for me.
      Living in my VrayPhysicalCam, with low Exposure settings... Now with Lightmapping.
      Spanish V-Ray 3.0 Licensed Instructor
      Artefaktos 3D&FX School
      @artefaktos3d
        easiest solution is definitly to put RT as production render, that's the way I'm doing all my animations, no scripting needed, just work as usual but with RT in stead of normal vray.
        Stan
        3LP Team
