Just what the title says. It happens regardless of the Maya scene I use. My current test scene is a polysphere on a plane and one Rect Light. Here's the info...
Mac OS 10.9.2
Graphics: NVIDIA GeForce GTX 770
NVIDIA driver = 331.01.01f04
GPU driver = 8.25.9 (331.01.01f04)
CUDA = 6.0.37
Maya 2015 SP2
terminal output:
I see people posting .dmp files when v-ray crashes but I'm not sure where those files are saved. If that info would be helpful then let me know and I'll post it as well.
Edit: I've also tried the latest CUDA driver (6.0.46) and gotten the same result.
Thanks!
Mac OS 10.9.2
CUDA = 6.0.37
Maya 2015 SP2
terminal output:
Code:
Gazoo:~ jgriffin$ /Applications/Autodesk/maya2015/vray/bin/vray -server -portNumber=20207 -rtPidFile=/tmp/vray_rt_pid_lK3vZl; exit [2014/Jun/2|12:39:09] Reading configuration from "/Applications/Autodesk/maya2015/vray/bin//vrayconfig.xml" [2014/Jun/2|12:39:09] =============================================== [2014/Jun/2|12:39:09] V-Ray Standalone, version 2.40.02 for x64 [2014/Jun/2|12:39:09] Copyright (C) 2000-2010 Chaos Group Ltd. All rights reserved. [2014/Jun/2|12:39:09] Use -credits option for additional third-party copyright notices. [2014/Jun/2|12:39:09] [2014/Jun/2|12:39:09] Build from May 15 2014, 14:57:28 [2014/Jun/2|12:39:09] Compiled with GCC-compatible compiler, version 4.2 [2014/Jun/2|12:39:09] Operating system is Mac OS X [2014/Jun/2|12:39:09] [2014/Jun/2|12:39:09] V-Ray core version is 2.00.02 [2014/Jun/2|12:39:09] =============================================== [2014/Jun/2|12:39:09] [2014/Jun/2|12:39:09] Loading plugins from "/Applications/Autodesk/maya2015/vray/vrayplugins/libvray_*.so" [2014/Jun/2|12:39:09] 104 plugin(s) loaded successfully [2014/Jun/2|12:39:09] Finished loading plugins. [2014/Jun/2|12:39:09] Entering server mode - waiting for render requests on port 20207. Press Ctrl+C to exit. [2014/Jun/2|12:39:09] Starting DR session from 10.1.10.16 [2014/Jun/2|12:39:09] Receiving DR scene from 10.1.10.16 [2014/Jun/2|12:39:09] warning: DR request received from 127.0.0.1, but currently busy with 10.1.10.16 [2014/Jun/2|12:39:09] Reading scene file "/tmp/vrscene.txt" [2014/Jun/2|12:39:09] /tmp/vrscene.txt: done [ 0h 0m 0.0s] [2014/Jun/2|12:39:09] Scene file parsed successfully in 0.0 s. [2014/Jun/2|12:39:09] Scene created successfully. [2014/Jun/2|12:39:09] Objects in scene: 0 [2014/Jun/2|12:39:09] Starting render sequence. [2014/Jun/2|12:39:09] Preparing renderer... [2014/Jun/2|12:39:09] Preparing scene for rendering...: done [ 0h 0m 0.0s] [2014/Jun/2|12:39:09] CUDA renderer requested. [2014/Jun/2|12:39:09] 1 plugin(s) loaded successfully [2014/Jun/2|12:39:09] CUDA renderer plugin successfully loaded from "/Applications/Autodesk/maya2015/vray/bin/librt_cuda.so" [2014/Jun/2|12:39:09] CUDA renderer plugin instance successfully created. [2014/Jun/2|12:39:09] EXT_RTOPENCL interface obtained successfully from CUDA renderer plugin instance. [2014/Jun/2|12:39:09] ======================== [2014/Jun/2|12:39:09] Starting frame 1. [2014/Jun/2|12:39:09] warning: Camera FOV is too small, possible round-off errors. [2014/Jun/2|12:39:09] Preparing scene for frame...: done [ 0h 0m 0.0s] [2014/Jun/2|12:39:09] Compiling geometry...: done [ 0h 0m 0.0s] [2014/Jun/2|12:39:09] Building SDTree for GPU [2014/Jun/2|12:39:09] Building SDTree for GPU [2014/Jun/2|12:39:09] warning: Scene is empty. [2014/Jun/2|12:39:09] Running RTEngine [2014/Jun/2|12:39:09] Initializing CUDA renderer (single kernel version)... vray.bin(1448,0x103a81000) malloc: *** error for object 0x1039071b0: pointer being freed was not allocated *** set a breakpoint in malloc_error_break to debug /Applications/Autodesk/maya2015/vray/bin/vray: line 3: 1448 Abort trap: 6 /Applications/Autodesk/maya2015/vray/bin/vray.bin -portNumber=20207 $* logout
Thanks!
