V-Ray Standalone has stopped working. V-ray rt 3.00.07 GPU Opencl
  • V-Ray Standalone has stopped working. V-ray rt 3.00.07 GPU Opencl
    I'm having a few issues getting v-ray rt working using the gpu opencl. Every time I try to render with either the production or activeshade mode I get to "waiting for image data" in the frame buffer and then "V-ray Standalone has stopped working" pops up. Works fine with the cpu just not the gpu.
    firepro w9100
    driver: 13.352.1009
    You will need newer drivers (version 14.20 or something like that). I don't know if these are officially released yet.
      Vlado,
      Worked like a charm. Thanks for your help.
        I also experience crashes with GTX 770 with CUDA.
        Driver version 340.52.
        Any idea what that might be?
          Which Vray version you are using?
          Does the crash occurs on every scene - have you tried to render a very simple scene with a few basic primitives?
          What about OpenCL mode? Does it work or not?
          Have you tried with older drivers like 337.88 ?
            I have discovered it happens when I use heavy HDR maps with dome light (around 400MB+)
            When I use smaller HDRs everything is fine.
            I will try 337.87 and report back.
            I red comperations online that most of them claimed Nvidia are crippled in OpenCL, so I don't want to use that on regular basis (yes, that same crash happens no matter OpenCL or CUDA)
              Is Resize Textures for GPU option activated?
Name:	2014-08-19 16_58_29.png
              Have you tried also to decrease the Resolution parameter from DomeLight properties?
