Hi guys,
I'm running into some problems and i have no idea what happened.
Everything worked fine until my latest restart.
After the restart, the VrayRT GPU isn't rendering at all. THE GPUs aren't engaging and no error messages or any messages are displayed at all. Only a black image.
The render window says "Rendering image..." but it's not even trying to load the scene as usual and that command-prompt window of VrayRT isn't starting.
It renders fine with the CPU though.
If i swap to Active-Shade, it hangs at "Waiting for image data..."
I have to mention that i haven't changed / installed / updated any software or anything in the meantime. Also, no render settings were changed. Also, the same problem persists on a completely new scene.
And it's not the drivers as i have seen in a different topic. In that topic, updating the drivers solved the problem.
I updated the drivers but it didn't helped.
It's not a hardware problem either as the GPUs are rendering just fine if i render with iRay.
The Vray license server is running in the background as usual.
Regards,
Peter Istrate.
Regards,
Peter Istrate.
