3ds max + V-Ray RT CPU - freeze on autosave?
  • 3ds max + V-Ray RT CPU - freeze on autosave?
    I'm using V-Ray RT in CPU mode, and I'm noticing that sometimes when 3ds Max goes to autosave while V-Ray RT is running, the entire program locks up and becomes unresponsive. I have to end the 3dsmax.exe task to close things down.
    Is anyone else experiencing something similar?
    Akin Bilgic | CGGallery.com
    Modeler & Generalist TD
    V-Ray Render Optimization
    V-Ray DMC Calculator
    That's the first time I see a report about this. Can you get me a dump of the 3ds Max process at that time - right-click on 3dsmax.exe in Task manager and select "Create dump file". Note that the resulting .dmp file can be really big, but it will tell me exactly what's going on at that time.
    Also, is this with the V-Ray VFB?
      Yes, it's with V-Ray VFB. Next time it locks on me I'll try to get that dump file for you.
      Thanks Vlado!
        Same as above. I've been dealing with this infuriating issue for the last two days. At least 20 crashes yesterday, and already 4 in one hour today.
        My dump file is over 6gb so I can't get it to you but I can say that it always happens during autosave.
        Max 2014, max vfb, RT CPU, vray_adv_31501_max2014_x64_25173
          It will be very helpful if you could send us this dump file or maybe the scene file to test it in our environment.
          We can supply our FTP to upload the file there, just contact us at support@chaosgroup.com and we will provide you with all details.
          Thank you.
          I did few tests, but could not reproduce the crash here.
          Tashko Zashev | chaos.com
            What Tashko said - the dump file will be really really helpful, as well as the scene if possible.
              Actually I just got this here... looking into it now. It seems to be related to the VFB message processing.
                @Akin: try the next nightly build tomorrow and let me know if it works better.
                  Still need the dump file then?
                    Yes, I still need a dump from you; your issue is likely different from Akin's (which was not a crash, but freeze).
                      Sorry mine was a freeze too. Not full-blown crash. I'll send it through when I can anyway.
                        Great to hear. I'm away from work for the next two weeks, but as soon as I get a chance I'll give it a try! Thanks again Vlado!
