Interface very sluggish when running Vray RT
  • Interface very sluggish when running Vray RT
    Since I switched to max 2016 and updated VRay to 3.20.02 I noticed that while previewing the scene with VRay-RT, the whole interface because extremely slow : dialogs take seconds to update, same for materials when I change any value.
    Please note that I run Vray-RT on the renderfarm and disable "Auto-start local slave".
    Anyone experienced similar issues ?
    mekene
    Just decrease the values of Samples Per Pixel (to something between 1 and 4 for example) and Bundle Size (to something between 32 and 128 for example). Test to see what works for you.
    You can check more about that here http://docs.chaosgroup.com/display/VRAY3/GPU+Rendering#, section "Balancing the GPU Load".
    V-Ray fan.
    Looking busy around GPUs ...
    RTX ON
