I'm having some major issues with Vray RT in the new 3.30.01 Build. usage and speed issues. I have a 3930k OC with 32gig ram, AMD W7000 for display, and Titan X for Compute, running Windows 10. All we use here now is RT, so finding a fix would be great!
1) The new integrated RT running in max process doesn't work with having a secondary compute card for us, will not find the Cuda Device. I tried Changing the GPU to TCC, that had major issues, one it renders very slow, two it does away with you cards auto fan control for heat, and the card heated up and was pumping HOT air out the back of the computer.
2) Tried running it as a DR service. Issue with that is that I have to run (C:\Program Files\Chaos Group\V-Ray\RT for 3ds Max 2016 for x64\bin\vray -server) from CMD prompt every time I want to render or keep the last one open. If not it doesn't find the Cuda device also. And getting this way to work the render times are much longer than from 3.20.03. Vray RT 3.2 - 21min55sec vs Vray RT 3.3 - 55min44sec. Also this mode doesn't seem to cache textures which really sucks.
3) The new Adaptive method doesn't seem to be working properly in RT, seems much faster and correct in ADV. Also RT doesn't render the same as ADV. Both are using BF,LC and progressive for ADV. I attached the rendering below to show difference in speed and render. Notice the couch and chairs especially are much whiter in the ADV rendering.
