Crash (reproducable) with OSL thin film map
  • Crash (reproducable) with OSL thin film map
    Max completely closesx without error when doing the following:
    1) Set up a scene with HDRI as light, and backplate as background in environment (Standard HDRI scene)
    2) Create a sphere and assign a glass material to it with IOR = 1.0
    3) disable fresnel reflections and put in the thin film OSL map
    4) Assign material to sphere and start RT. Everything works as expected. Leave RT running when doing the following steps.
    5) Create another material, a VRayLightMtl, assign a noise texture to it, check "compensate for camera...".
    6) Put the same noise map (instance) into the thin film thickness.
    7) Assign the LightMtl to the sphere.
    Either here or during the following it will crash:
    9) Change any parameter in the noise texture (size for example)
    3ds max Design 2014 with latest SP
    latest VRay stable release
    Software:
    Windows 7 Ultimate x64 SP1
    3ds Max 2016 SP4
    V-Ray Adv 3.60.04
    Hardware:
    Intel Core i7-4930K @ 3.40 GHz
    NVIDIA GeForce GTX 780 (4096MB RAM)
    64GB RAM
    DxDiag
    I followed the steps described but didn't get any crashes when render with RT CPU or CUDA.
    Can you attach your file or send to support@chaosgroup.com?
Name:	2016-04-12 14_06_04}.png
    Tashko Zashev | chaos.com
      Thanks.
      Uploading atm with the name "Bubble_CG.zip" on your FTP server.
      I noticed sometimes it takes me 2 to 3 times changing the noise size until it crashes.
      Software:
      3ds Max 2016 SP4
      V-Ray Adv 3.60.04
      Hardware:
      64GB RAM
      DxDiag
        Thanks, we are downloading it right now.
          The crash is reproducible with 3.30.05/ Max 2014 but seems to work stable with latest nightly builds and Max 2016. I'm going to test a bit more..
            Alright, good to know! Thanks!
            Software:
            3ds Max 2016 SP4
            V-Ray Adv 3.60.04
            Hardware:
            64GB RAM
            DxDiag
              Hi again,
              Just to let you know that the issue is reported as a bug in our system.
                Fixed for the next V-Ray service pack!
                  Thanks for letting me know!
                  Software:
                  3ds Max 2016 SP4
                  V-Ray Adv 3.60.04
                  Hardware:
                  64GB RAM
                  DxDiag
