Why is RT rendering with color differences compared to the ADV production renderer? I remember having these issues before, are they still not fixed or is there something in the shader not supported? this scene is just Forest pro preset items.
Vray RT color differences
It is because RT is completely different engine in the current version of V-Ray.
Is this CPU or GPU ? Either of those, even if only with presets, it will be best to send the scene to look over it. I would guess that it is some forest pro specific shader.V-Ray fan.
Looking busy around GPUs ...
RTX ON
Originally posted by svetlozar.draganov View PostThank you very much for the scene.
It seems that the Forest Color and Color Correction maps are not fully supported and their are rendered slightly different on the RT CPU, the difference is not so drastic though.
The difference is due to the fact that the GPU still calculates reflections for the leaf material even though they are disabled. Please note that V-Ray RT GPU doesn't support Trace reflections options. If you enable Trace reflections option this material will render as with the CPU.
Edit: This behavior will reproduce only when having Highlight glossiness value less than one. I'll make a not about that.Last edited by Zdravko.Keremidchiev; 19-05-2016, 06:50 AM.
