VRayEdgesTex, Diffuse map issue
  • VRayEdgesTex, Diffuse map issue
    Hello,
    I have little isue when I use VRayedgesTex as Diffuse map on RT Rendering (CUDA).
    I can see the material when vray calculate light cache, but it's black when rendering.
    light cache calculation
    rendering
    material
    Hello,
    The light cache calculations happen on the CPU and the VRayedgesTex is supported there. After that the actual rendering happens on the GPU where the edges tex is not supported and you get black color. (https://docs.chaosgroup.com/display/...orted+Features)
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      OK, thanks for explanation.
