Can't see changed textures until Active Shade is replaced with Production Renderer
  • Can't see changed textures until Active Shade is replaced with Production Renderer
    I'm rendering a scene with RT and from time to time I stop it to adjust a texture in Photoshop and then I run RT again. The problem is that when I save the texture I don't see it updated in the RT renders even when I completely stop (not pause) the RT render and run it again. I tried both CUDA and CPU. The updated texture appears in the render only when I switch from Active Shade to Production Renderer and then back to Active Shade again. Is this normal? Hardware and software specs in my signature below.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    You are right, thanks for the report !
    As a workaround you can turn off in-process RT engine.
    Peter Matanov
    Chaos
      Ok, I will have this in mind, thanks.
      Aleksandar Mitov
      96GB DDR5
