I'm rendering a scene with RT and from time to time I stop it to adjust a texture in Photoshop and then I run RT again. The problem is that when I save the texture I don't see it updated in the RT renders even when I completely stop (not pause) the RT render and run it again. I tried both CUDA and CPU. The updated texture appears in the render only when I switch from Active Shade to Production Renderer and then back to Active Shade again. Is this normal? Hardware and software specs in my signature below.
Can't see changed textures until Active Shade is replaced with Production Renderer
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 5090 32GB + GPU Driver 572.83Tags: None
Ok, I will have this in mind, thanks.Aleksandar Mitov
96GB DDR5
