RT CUDA Active Shade - Unhandled Exception c0000005 when updating textures
  • RT CUDA Active Shade - Unhandled Exception c0000005 when updating textures
    I'm getting Unhandled Exception c0000005 error with RT CUDA as Active Shade in the scene where I test my materials in. This happens only in this particular scene and only when I save a texture with Photoshop that is already used in the scene. Screenshot below:
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Hello,
    Can you share the scene and the texture ?
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Hi Yavor,
      I just did. Let me know if you need any additional information.
      Aleksandar Mitov
      96GB DDR5
        Thanks for the scene - I reproduced the problem here.
        There are two possible workarounds till we fix the issue:
        - Turn ON "Auto update bitmaps" - that way V-Ray RT will watch for changes to the file and update the bitmap correctly when you save the texture in Photoshop.
        - Use VRayHDRI instead of Max's bitmap - also seems to fix the problem
        Yavor
        Yavor Rubenov
          Thanks so much, Yavor. Why didn't I see that "Auto update bitmaps" button, I totally overlooked it!
          Aleksandar Mitov
          96GB DDR5
