RT CUDA erro - [VrayRTMax::renderThreadProc] Exception occured in rendering thread.
  • RT CUDA erro - [VrayRTMax::renderThreadProc] Exception occured in rendering thread.
    There's a scene where I use RT CUDA as Active Shade and I'm getting the error below every 10-15 min. When this happens the Stop render button doesn't work so the only thing that fixes it is to restart Max but 10-15 minutes later the error would appear again. The scene consists of a a Vray plane object, a physical camera, 2 dome lights with HDRI textures and a group of objects which is an Xref scene. This Xref scene consists of Xref objects and has Xref Materials applied to all objects.
    Update: I got that error again in a completely different scene. What I was doing is I was editing a VrayBlendMtl and plugging maps in the slots of the Coat material.
    Click image for larger version  Name:	RT_exception_rendering_thread.png Views:	1 Size:	12.8 KB ID:	957245
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Hello,
    When you get that crash - V-Ray will write a crash dump called VRay.dmp in the temp folder - could you send one such dump (and if possible - the scene).
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Ok, I'll do so next time it does this.
      Aleksandar Mitov
      96GB DDR5
