Shadow catcher alpha not sampled well
  • Shadow catcher alpha not sampled well
    It seems that there are problems with sampling the alpha of shadow catchers in RT CUDA. They render way noisier than Adv even at noise threshold of 0.005. Is there something that I can do to make the shadow catcher's alpha smoother?
    Please check the screeenshot below. This is a sphere on a plane and a Vray plane light. All render settings are at default.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    GeForce RTX 3090 24GB + GPU Driver 566.14
    Does it gets cleaner if you add lower noise treshold (comparing noise thresholds between Adv and V-Ray GPU sometimes can have those effect)?
    Best,
    Blago.
    V-Ray fan.
    Looking busy around GPUs ...
    RTX ON
      Hi Blago,
      No, the alpha looks exactly the same down to the individual pixels, even if I lower Max noise to 0.001. The RGB channel is silky smooth though at this noise level.
      Aleksandar Mitov
      96GB DDR5
        Thank you for this report Alex.
        It looks like the alpha noise level is not considered for the current noise threshold level in GPU mode and I'll make a note in our system about this.
        Until we have this improved in the builds you can slightly increase the Ray per pixel parameter until you get the desired image quality. I also found that setting the Max noise thresh. to 0 make the alpha very smooth but this is not really an option since the render time will go up a lot.
        Tashko Zashev | chaos.com
          Setting Rays per pixel to 64-128 worked, thanks! It's still not as smooth as I want it but it's much better.
          Aleksandar Mitov
          96GB DDR5
            Looks like this is the same issue I posted about yesterday morning - although much better explained by Alex. (Thanks Alex) https://forums.chaosgroup.com/forum/...shadow-catcher
            Indeed, increasing rays per pixel helps a lot but doesn't solve it.
            Freelance 3D Generalist
            www.maxwood.co.uk
              Minor bug I've noticed, when right clicking to reset to the default rays per pixel value it doesn't respect the engine type chosen.
              Resetting rays per pixel when using CUDA changes to 4 (should be 16).
              Looks like it's taking the default value from CPU instead.
              www.maxwood.co.uk
                I'll forward this to our developers. Thanks!
                  We have fixed the noisy alpha issue for the next update of V-Ray 4.
                    Brilliant, thanks Tashko
                    www.maxwood.co.uk
