Saving image channels = Errors writing 1 of the images
  • Saving image channels = Errors writing 1 of the images
    When using RT as production renderer and trying to save all image channels (in VFB) I always get an error message: "There were errors writing 1 of the images"
    But the images seem to be alright. Are my images really alright or somehow damaged? The message is a bit confusing.
    Regards
    Olaf Bendfeldt
    3D-Artist
    dimension3+
    Can you get us some way to reproduce this? Also, do you get the same error with 3.60.02? It was uploaded last week and includes a fix that may be related to your issue.
      I just updated to 3.60.02 and get the same error. But I found the culprit, it's the MultiMatteElement. When deleting it from the render elements the error is gone. It's only RT related not Adv.
      Olaf Bendfeldt
      3D-Artist
      dimension3+
        Would it be possible to attach the scene with just the render elements setup? If there is an issue, I'd like to fix it.
          Hey Vlado, I attached the scene. Additionally I found out that the error only occurs when isMATID is enabled.
          Regards
          Olaf Bendfeldt
          3D-Artist
          dimension3+
            Hello,
            Thanks for the scene - we reproduced the issue - indeed it is because of the isMATID option. You can safely ignore the error message in this case.
            We've also added a fix for this for a future V-Ray version.
            Yavor
            Yavor Rubenov
            V-Ray for 3ds Max developer
