alpha from refracted material not the same
  • alpha from refracted material not the same
    Minor difference in alpha output from refracted material between RT gpu and RT cpu .
    I believe cpu is correct.
    www.nikand.com
    3D Freelance
    Both alphas seems identical on our side, can you share the scene?
      the window had 3 layers of glass that's why it's more prominent I guess.
      Made a simpel scene with a box 60x100x1xcm
      And the same scene with edit poly on top to copy element twice to get 3 layers.
      Also the refraction differs a lot.
      I will send the scene.
      www.nikand.com
      3D Freelance
        And here is rgb layer of the 3 layer glass.
        1 layer looks fine though.
        www.nikand.com
        3D Freelance
          Thank you for sending the scene. Both of the issues are now logged in the bug tracking system.
            About the refraction mismatch: V-Ray GPU uses the min of the Max depth value in the material itself instead of the Trace depth.
            We are investigating the Alpha issue.
